Neal3000
you should be able to get that pin machined off and then drilled to fit the tbe pins if you can find a good machinest......paging ZukBilly
personally i wouldn't use 5.29's in a toyota, taking a marginal diff and making it as weak as possible is a bad idea imo.......get your gearing in the t-cases if possible and go for maximum strength in the diffs
