Rockwell Axle build at CCOR "The Hitman"
tiny said:
The finished product is missing some bolts.
What kind of brakes?
Are the lower links going to mount below the steering?
Pictures are technically before the true final assembly .
He's got Overson Pinion brakes.
Lower links will be below the axle somewhat but they will likely be triangulated so they will be on the outer end close to the wheels which will help with ground clearance.
Yes the steering is behind the axle.
Travis has a new color scheme for this buggy. See the Wheels
Gear marking compound was just to see what the pattern on the rockwell looks like.
As far as going with heavy axles your going to have to talk to the Hitman about that but I believe its mostly due to strength.
I believe it took about 1-2 weeks to get the axles from Overson
The chassis is being built now at Sosebee's Performance.
I'll attach some pics he posted up.
These pics have been up for a week or more so I'm not sure how much more progress as already been made.
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Re: Re: Re: Rockwell Axle build at CCOR "The Hitman"
kushKrawlin said:
Is this the same buggy that has the mohawk on the top made from short pieces of tube? I saw it two weeks ago at choco.. Looks like the same one.. I wanted to cut it off for him. :****:
Looked like the hawk was made from pool float noodles in the video....8)
0 Words
