running propane
Here are a few posts that I wrote during the install of the propane system...
Today I received the second box of the Propane kit from Cary at www.GotPropane.com
The kit includes the parts below along with a tank bracket and air filter:
I started the installation process by attaching the regulator to the firewall. I drilled a couple of holes and attached it using the provided bolts.
Next I mounted the tank T connector. I used a shock tab from Polly Performance to mount the "T" to the top of the rear upper link suspension. For safety, the propane line needed to be protected as it is routed from the tanks to the engine. I kept this in mind as choose the route for the hose.
I marked the propane lines for the length I needed and tried using a pair of side cutters to cut the hose. I had assumed that the hose was like water or fuel hose. The hose laughed at the side cutters. Ok I put the hose in a vice and brought out the Sawzall, that got the job done. After cutting the hose, I found the hose has a steel layer that really makes this hose tough.
There are two lines that are needed for the instalation. One from the tanks to the "T" connector, and a second hose that goes from the "T" connector up to teh regulator on the firewall.
Once the lines were cut, I installed the ends that are provided in the kit. These are easy to put on. Each end is made from two parts. Starting with the larger outer shell, this get twisted onto the outside of the hose using it's left handed threads. Next I placed a dab of grease on the smaller inner tip. This is threaded into the larger part with the help of a wrench.
Today I installed the throttle body base. This unit has a single hole that leads to the primary and secondary holes in the intake manifold. The material between the primary and secondary openings is right in the middle of the fuel/air flow down the center of the throttle body. For this reason Cary at Got Propane recommends removing this section of the intake manifold for best performance. The photos below show the interference between the two plates and the flow.
I used a standard 4" grinder to remove the material from between the ports. I first stuffed two small rags into the intake manifold ports. Next I cut out the section with the grinder. Then I used a flat hand file to finish the edges. Photos below show the new opening. I also cut a new gasket to match the opening.
The lower section of the throttle body bolted into position...
Here are a few install photos of the propane system. For hooking up the throttle, I used the factory Samurai throttle cam. After drilling a couple of holes in the cab, it gets bolted to the throttle plate.
Thanks for posting that!
I see your throttle cable bracket that looks simple enough :awesomework:
Thanks again
so how much propane did you guys use running the rubicon trail? and are those the 33lb tanks? thanks.
Each tank holds 8 gallons. With my Samurai I was able to drive in from loon and to the springs. Back to spider and again back to the springs. Then back out to the start of the trail on just one 8 gallon tank.
Matt's Ftoy uses about twice the fuel I do and nearly finished two bottles going from loon to the springs and back. You get about 5 hours of realy hard driving on one 8 gallon tank of propane.
Just filled my tanks for $1.99/gal at Flying J in Fife. I'll be filling up again on the way home here though:
seattle-tacoma craigslist > south king > recreational vehicles > ~ ~ RV PROPANE~ ~ $ 1.69 per gallon EVERY DAY ! ! !
Avoid scams & fraud by dealing locally! Beware any deal involving Western Union, Moneygram, wire transfer,
cashier check, money order, shipping, escrow, or any promise of transaction protection/certification/guarantee
please flag with care : [miscategorized] [prohibited] [spam] [discussion] [best of]​
Reply to: [email protected]
Date: 2007-05-21, 10:11AM PDT
Recreational Vehicle Propane!
PROPANE FOR $1.69 PER GALLON EVERYDAY!!
Get your propane here!!
No minimum purchase!
Cascade Distributing sells propane for $1.69 everyday and for any quantity; 1 gallon on up!
Sorry, we do not deliver; this is "picked-up" price only.
www.go2bud.com
(253) 862-5766 (Bud - Sales - Monday through Saturday)
(253) 862-5765 (Lisa - Bookeeping - Weekdays Only)
Hours: Monday through Friday - 9:00 AM to 6:00 PM
Saturdays - 9:00 AM to 5:00 PM
We are closed on Sundays.
We are located at 9910 233rd Ave E and Hwy 410, between Buckley and Bonney Lake.
(next door to Hi-way Gas & Grocery)
  • [*] Location: Buckley - Bonney Lake
    [*] it's NOT ok to contact this poster with services or other commercial interests
PostingID: 335334899
Copyright
