Ty.
Missing links may unload at the worst of times. Toy axles with wrangler springs flexes great, its an easy set up and you won't need any ladder bars.
With the lift springs and a SOA I would be up around 10" or so. With the toy axles and some 34 or 35 skinnys would I be asking for trouble? I plan on a locker and 5.29 gearing in the toys. :scratchhead:
I have heard of the missing links unloading but mostly the revolver ones. Trail Tough had some and I was not to sure what the thought was about them on the sammys.
Cam shaft on any of those engines will make a difference. 1.6 is the easiest swap. Add a torque cam to the mix and it is night and day difference in power.
I run the missing link kit from TT and like it a lot.Tons of flex and had no problems on tough trails with unloading,run a rear traction bar because you will destroy your rear springs and the yoke on your drive shaft.With the lift springs and a SOA I would be up around 10" or so. With the toy axles and some 34 or 35 skinnys would I be asking for trouble? I plan on a locker and 5.29 gearing in the toys. :scratchhead:
If you are not running EFI or planning to, you can do a Harley carb swap. Zuks Off Road (ZOR) sells a kit as well as Petroworks.
I built my own setup however. I'm all into my setup for about $85 including the carb (ebay) and the Uni airfilter. Here is a pic of my setup.
It runns really strong on my old worn out 1.3, but I have yet to adjust the jets for my new 1.6 but it still pulls very hard.
What size carb is that? Sounds like a cool idea. Has anyone else had issues getting the stock door hinge's off? The scews are stuck on mine. I was thinking about just cutting the top peice off the hinge and going half doors. Will just the lower half hold the weight? Thanks for all the in put:beer:
