throttlejunkie said:I've thought about the cats, but would that come on so sudden?? Also, I see the pressure is a little low, but would that cause the injectors to fire that poorly, casue its having a hard time even idling now. Its straight up acting crappy now!
throttlejunkie said:Well threw some intake gaskets on er, no luck. Loaded it up took it and had it scaned , again...said mass air. Got a new one...still same issue.![]()
pillsbury said:What state do you live in?
tunedportcj5 said:Check ALL of your grounds. Depending on your harness - especially check your O2 grounds.
throttlejunkie said:According to GM the fuel is good. Flex fuel 5.3 had less pressure 42-48. I started to swap the pump, already swaped filter, but with that pressure it would suck to replace it for no reason. Still several things and sugestions im goona try. Blows me away after having it hooked up to a bad ass snap on computer and even it was wrong. Guess it wasnt as bad ass I thought.
