74_Chevota
Big ole' can uh peas!
Re: Clayton, OK 7/2008
The thing that throws me is how mine broke (the exact same way) and everything was mounted the same as yours. Added weight of the stak? Either way, it brings the suck when it happens.
GStone said:I can only offer how mine is done. It solid mounts off the adapter to the cross member which is bolted to the main frame rails using poly bushings. The motor is mounted to the chassis by poly bushings also, there is enough clearence around the headers and the frame rails to slip maybe two playing cards and my exhaust has never hit the frame from motor torque. My point is, nothing is mounted on any kind of rubber or anything that has "give" in it. From seeing other rigs that have had a "tranny case breaking problem", I usually observed that either the tranny, motor or t-case had rubber mounts mixed with solid or all rubber mounts. I haven't seen one that had everything more or less soilid mounted break tranny cases. Now, I'm only speaking from person experience, I don't doubt there are exceptions.
After saying all this it's likely to break the next time out.![]()
and switched to a th400 & a roark support ring.
