littleblue4runner
Active Member
Ok this might be a stupid question but is there a front solid axle that would work for an 89 Toyota 4runner that is not a Toyota axle? I don
I know it has to be a passenger drops so would a ford axle work?
Ford is drivers side drop so negative there big chief!! chevy yes
Older wagoneer would be better than a chev. closer to the same width of a toyota and most have flat top knuckels. But i would just put a toyota axle in it and be done.
If you are having a hard time affording the 300.00 for an axle why not just leave it alone?
250-300 for an axle
200 for highsteer
0-200 for install
50-200 for new leafs
50-200 for shocks
Going solid axle isn't cheep.
But you can wheel the fawk out of IFS. Left stock height, and with 31" tires you can do just about most wheeling in the NW.
Cut the rubber bump stops till they are only 1/4 inch thick.
Take out the sway bar.
Leave the ride height alone !!!! or you lose any flex you might have.
Put a shackle lift in the rear.
Have fun, and spend the savings on beer and ribbed for her pleasure condoms
FYI the last 3 totally stock toyota solid axles I purchased were 250.00 Each. They are out there, you just have to find the ones that arn't gold plated :;
Why is this in the ****ing classifieds anyways???
Get an idler arm brace, too.
ANd I've got a full set of budbuilt skidplates/flat crossmember for sale.
