Some tow rig lovin
Question Crash
When you installed the FASS where did you install the fuel line pressure sensor?
It does not look like you put it on the pump?
Thanks
I will get a pic tonight. I made a bracket that bolts to the side of the intake and took a brass T and mounted the sensor to that and then all of that mounted to the the bracket.
Where did you get the T fitting from? Local? Assume it is a push lock still?
Thanks for the info.
If I remember correctly it was just a simple 3/8 brass T. I could not find barb fittings if I remember correctly so used a standard 1/2" nipple/clamp.
Here ya go..
No problem Lokey.. Not allot of room to get my phone down in there but with the injector lines out it made it a little easier.
when you put your injectors in did you see a big increase in mileage?
I installed rv275s and haven't calculated the mileage yet but its a lot better
