cameron_garrison
- Joined
- Jun 2, 2006
- Messages
- 254
so im trying to decide which im going to step up to lets here pros and cons for them
9's
Your still running parts that can be had. 9's are more common than 60's(especially in all those old bowtie hotrods:fawkdancesmiley: )
With spiders you would be running ford units and probably wilwood brakes. That's a pretty good combo.
Then again at the $ you'll spend on SPIDER 9's you should be comparing to dynatrac prorock 60's not just 60's so either would do the job.
btw.. how's the pats collecting coming for your D30 replacement
:corn:
so does anyone else have an opinion on why the clearence is the only thing im thinking why i wouldnt want to run them
X2 wassup:kissmyass:did I miss what these are going under???....and w/ what powertrain, and tires...???.....
and.....some indication of driving style or intended use (comp rig, toy, beater)
and, by saying that you're considering the spyder stuff....does that mean you're willing to drop big money to get every last bit of performance/clearance etc....???
(60/14bolt) bitches.....
