tonybolton
Bypass Crawler
The courses I see'm run they're pretty much goin straight.
clemsonjeep said:Tidwells front axle was doing some strange stuff...sometimes 100% locked and other times like it was open...
so he just has the 16 spline chromolies?Cole said:Pretty sure it got damaged last week when Nathan broke both from Chromolly Ouverson shafts.
And Richie runs an ARB and he had it turned off when he climbed it one time.
fordcontraption01 said:so he just has the 16 spline chromolies?
2" shafts are a lot more fun you don't have to let off or worry about a wheel being in a bind lol!Cole said:He did in the front but broke them last weekend and put stock back in until his 2" shafts arrive.
tonybolton said:The courses I see'm run they're pretty much goin straight.
my buggy is a Lincoln "welded" locker the other weekend at AOP I broke both front axles and I should've checked chunk when I seen the twisted splines on one axle and shaft was broke in middle So I'm thinking the splines are twisted inside carrier or weld broke. Either way gotta blame Katiexjkrawler said:what front locker is in plow boy and tidwells buggy?
Nathan, I would buy parts for my buggy all week if my wife would drive like yours does. You have GOT to be proud of her!!NTIDWELL said:my buggy is a Lincoln "welded" locker the other weekend at AOP I broke both front axles and I should've checked chunk when I seen the twisted splines on one axle and shaft was broke in middle So I'm thinking the splines are twisted inside carrier or weld broke. Either way gotta blame Katie![]()
infamous1 said:Dang, Adairs little rig is working good!!!
Elliott said:Did bobby not like those other shocks that he tried?
patooyee said:He took a hard roll on his like second ride with them and broke the rear ones, didn't he? I think I recall seeing a video of it.
