Starting a build!!!
littleblue4runner
Active Member
Bothell WA.
Ok so I would like to start a project truck to build up, so the big question is what to get to start I do have a Toyota and have worked ok it a lot but I am open for whatever. Mostly mud but would like to do some rocks.
1 what truck?
2 what set up?
3 what would you do?
Thanks guy
Subaru Brat, ZL1 Ramjet, th475, 4 speed atlas, 54" Claws, all cromo double beadlocks, modular billet aluminum chassis, super 14 bolt chunks, 40 spline ARB, Ouverson aluminum Super 8 hubs & wheel brakes, all 300m RCV 2.5 ton 40 spline CVs, fabbed knuckles, 4ws, ORI struts, etc....
1 what truck?
2 what set up?
Thanks guy
X2, but a yugo with a polished aluminum snorkel. :cool:
Dont forget the Gigglepin 8274s with all the extras front and rear for extraction duty.
Seriously though, my vote would be a basic Toyota wheeler, small lift, lockers, and t-case gears or doubler. Put some 35 or 36s on it and learn how to wheel. That would be a good platform you could build on. :D
is your rig a v6? if so i would consider selling it and buying a toyota with a 4cyl for starters you can buy early 80's rigs all day with some sort of a lift and tires for around 1000-1500
I'm guessing that you're on a pretty tight budget. If so just put a locker in your runner and play around on some easy stuff until you get out of school. If not then a semi-built Toy will be perfect for ya.:;
yeah i am on a tight budget but a friend has a @#$& ton of toyota parts. so maybe give him a call.
what do i get first for my 4runner
