zukkev
Cornfuzzled yet again...
Will definitely be doin' that, as I'm just around the corner!!!
You're not far from Harmony Elem. then?:corn:
Will definitely be doin' that, as I'm just around the corner!!!You're not far from Harmony Elem. then?:corn:
If you ever want to upgrade to a better rear axle, the H233b out of a pathfinder is a great option. 4.37 gear ratio in the 5 spds, 9.17 inch ring gear, factory disk brakes, factory LSD, and most popular aftermarket lockers are avalible for it. Plus they are cheap as dirt.
any factory lockers for a Nissan?
Ummmmm...Scott, you've mounted the rear diff upside down....:yikes: And how's those shackles gonna work....to me they look like they will fight each other when the susp is being cycled....
update
