C
Cole
Guest
Which TH-400 Case is the Strongest and Why? I have heard so many different stories I don't know what to believe. I know some of you knowledgable people on here have the answer.
KyTrash said:That's what I thought but I'm not sure. A few people I have talked to said there all the same then some say there different. That's why I'm trying to find out.
johnnyrude said:If you can find a th400 out of cucv with diesel those were the hd series and have Ed at ptc to build it it will be bulletproof that just my 2 cents
Yeah I will have PTC swap over the internals because that's who built it originally.
Here is my transmission I just pulled out. It has HD stamped on the bell housing
Cole said:All my stuff is hard mounted. My case broke because the mid shaft wedged into the transmission when the yoke on the atlas broke.
I was just curious about the different cases. I'm not worried about the way it is mounted because its been that way since it was built and I've thrashed on it and not had problems.
mrdrinksalil said:Call your local transtar. Mine sells cases for $150. They sell the "HD 4x4" case for $260 but there wasn't one in the entire country when I called.
trentp said:Yours. Looks better than mine
