the_white_shadow
- Joined
- Dec 25, 2014
- Messages
- 816
- Reaction score
- 0
Sway bar is mounted. The bar flipped 180* didnt seem to help to match the angles of the bars so I went with what Scott said and mounted the lower arm on the passenger side to help combat the natural movement of the body when throttle is applied. The mount is further down on the axle tube but still uses a 16" end link like the drivers side.
My radiator came in yesterday as well. Its a Griffin 26x15.5x3 and has LS inlet/outlet. Its going to be tight but I think I can fit it up front. I have about 3/8" of an inch clearance from the bottom of the radiator to the link mounts on the truss. I may limit the uptravel just a tad to ensure they play nice together.
Ill probably lean it back some to keep it under the hood.
Also mocked up the Atlas. Apparently the mounting pattern of an Atlas isnt symmetrical. Since i flipped the adapter upside down the studs dont quite line up with the holes in the adapter so i took them out (had to do it anyways to get it at the drop i was after. So I have a couple options now. Take the ring off the front of the atlas and flip it 180 or use 5 out of the 6 mounting holes and waller one out some for the stud to go though the adapter. Oh and taking the studs out of the atlas sucked balls. Why couldnt they use hex heads on the studs. Using vice grips was awful.
Probable drop of the atlas.
The midship is going to be a cute little guy. I ordered up the carrier bearing from WOD. Once that comes in I can mock everything up. I plan on mounting it to the subframe tied in to/above the lower link mount.
Side view.
The rear mount should be easy enough to put together. I have a TMR mount to reuse and will mount it off the rear lower link crossmember.
Side view.
