The Gremlin - Toyota beater truggy build
Re: Re: Re: The Gremlin - Toyota beater truggy build
hjpcummins said:
Mind sharing you part numbers list for your hydro steering setup?
Ram is a 2.5"x8" from Surplus Center
Orbital is a 150cc Sauer Danfoss non-load-reaction that I picked up used
All fittings and field service hose came from Discount Hydraulic Hose
Pump is a stock Jeep cherokee pump i got from the pull-a-part
Power steering pulley and splined column are trail gear parts
The cooler came from the junkyard too
hjpcummins said:
Thanks! What's with the jeep pump.?
It's a saginaw TC pump, same pump that TG and PSC use in the kits, just modded for remote reservoir.
It puts out more pressure and volume than a stock Toyota pump
Neal3000 said:
finally, please quit F'ng around with this pissy little thing and get to buildin' your badazz buggy dude!
With the new job you should be home more!
ridered3 said:
Gremlin came together nicely! Like the idea of carb return spring to keep lines out of the way.
**** is ****ed up and we left it in the woods!
Re: Re: Re: Re: Re: The Gremlin - Toyota beater truggy build
What'd you break?
Re: Re: Re: Re: Re: Re: Re: The Gremlin - Toyota beater truggy build
The Luke said:
What'd you break?
Head gasket blew between #3&4 pulled the plug wires and injector plugs, kept riding.
Steering overheated
A few times
Broke a hydro fitting off the ram.
Left it in the woods
Sitting at a Mexican restaurant.
Steering overheated
A few times
Neal3000 said:
The Asian Gods will punish you for this
:wtflol:
Re: Re: Re: Re: Re: Re: Re: Re: Re: The Gremlin - Toyota beater truggy build
Steering overheated
A few times
El Tap can fix anything.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: The Gremlin - Toyota beater truggy build
Pretty much.
I felt a lot better about it after some carnitas.
Going to go try to get it out of the woods before the storms get here
Well the gremlin was extracted from the woods, and we tore down the motor, head gasket wasn't blown, but the bottom end was so wore out that 3 and 4 didn't have compression
Time for a 2rz swap. Haha
Steering overheated
A few times
This is why I like buying something already built! :****: I'd never have the patience to build anything
the gremlin's shakedown run...
Why does this thing sound like a tractor?
Why does this thing not turn?
I think the power steering fluid is boiling...
