paradisepwoffrd
He can do the widening mod and then can be able to use the short side shaft on both sides. Can also modify the shafts to take explorer CVs, iirc. They are a little better than stock.
Biggest thing that will help is gearing. Mine on stock gears and 34s was a turd. He can do 4.24s in the stock case. I also modded my case for twin stick and 2wd low. Was cheap and easy.
Or he can put in a sami case. Stock same case with no change otherwise will help a ton on gearing.
If hes going sami axle, finding a kick rear and building a hybrid would get him between sami & yota, esp with RCVs.
I would jump straight to yota front. Redrill pattern if u wanted. If want to go yota rear later, switch back.
