John Galbreath Jr.
38 Special & Solo Buggy
- Joined
- May 24, 2007
- Messages
- 8,613
- Reaction score
- 3
Sure everyone has their own ideas. Some based on size. I have mine in a soft sided bag that fits behind the seat in the Solo Buggy.
I carry:
Tire plugs
Tire plug glue
Tire plug tool
Lighter
Allen Wrenches
Needle nose vice grips (to clamp off broken brake line)
Small vice grips
Large vice grips
Sockets from 1/4 to 3/4
Ratchet, 3" & 6" extensions
Open end/ box end wrenches 1/4 to 3/4, plus 10mm.
Hammer
Regular screwdriver
Phillips Screwdriver
ARB air line - 10'
ARB union repair kit
ARB air switch
Wire - 15'
Wire crimp tool
Fuses
Wire connectors and terminals
Fuel filter
Fuel Pump
Wire ties
Electrical tape
Side cutter pliers
Channel lock pliers
Adjustable wrench
Air hose with air chuck
Air gauge
Air blow off tool
Clevis
Hydraulic fittings
Assembly lube
Mirror on stick
Magnet on stick
Coilover spanner
Pocket knife
Bolts, nuts, washers, lock washers in 1/4", 5/16", and 3/8"
Lokar transmission fill tube adapter
I do not carry a tree saver of strap as I have rope on winch.
Thought this would be thought provoking for what to carry. What do you carry not on my list??
I carry:
Tire plugs
Tire plug glue
Tire plug tool
Lighter
Allen Wrenches
Small vice grips
Large vice grips
Hammer
Regular screwdriver
ARB air line - 10'
ARB air switch
Wire - 15'
Wire crimp tool
Fuses
Fuel filter
Fuel Pump
Wire ties
Electrical tape
Side cutter pliers
Channel lock pliers
Adjustable wrench
Air gauge
Air blow off tool
Clevis
Hydraulic fittings
Assembly lube
Mirror on stick
Magnet on stick
Coilover spanner
Pocket knife
