This really sucks
Jimbo said:
I'm running a 350 turbo with a Ultra Bell, one of the best choices i made in a while was the bellhousing. After breaking two transmissions in half Brian told me about the Ultra Bell which bolts to your pump (this is after you cut the stock bell housing off the front of your tranny)which works. It's rated up to 1200 hp and is 600 times stronger than the factory set up.Well worth the trouble when you consider the time and expense to build a new tranny and reinstall. pepper.gif
Yeah, it takes a beating in those videos...you reving the motor and droppig it into gear like that.
Where did you get the Ultra Bell?
Jimbo said:
Brian ordered it from Jegs i believe. Still no word on the rest of the motor, maybe some news tomorrow. :popcorn:
Ultra Bell is on the way....................thanks Jimbro for the tip.
No problem, just take your time when cutting the front off your transmission. Very important that the bell fits tight against the transmission and use plenty of Locktite on the bolts going into the pump. You'll be glad you made the change!!!!!!!!!!!!!!! pepper.gif
