nhl_bullitt
Southern IL/MO
lowbudgetjunk said:If you ever find yourself saying...I could use more power, or if I had an automatic. Buy an LS, auto, tons and some sticky's. No one with that combo has ever said, "I wish I had half the cylinders, a manual, a 10 bolt and some Ground Hawgs."
laughing1
So first off, I'm a believer in lighter is better. Keep that in mind with any build.
It depends on the wheeling. Rock crawling large boulders on level ground can be done with skill and anything that has power to 4 wheels.
However, I will use an obstacle at my local park as an example. It is right off of an access trail. No it is not some long, loose steep hill, or something you have to jump. But you are not going to idle yourself up it. You need wheelbase and readily available wheel speed. After your front tires crest the top, and while you are still moving forward, you have to mash the gas with a purpose. I don't have much, but the mild 350 and 5.13s gets the job done every day I try it. FWIW, I literally have never seen anybody else make it in person, and this is the place I go to every month. Other people make it, especially buggies, just not who I'm with I guess.
Like a lot of hillside ledges deep in the woods, it almost always has a slimy texture to it. That is just a physical example of what I come across a lot while wheeling. Stickies have absolutely helped the cause for getting away with less HP but sometimes it only goes so far.
Again, what obstacles are you hoping to conquer out there. Totally up to the builder/driver.
The yj in the pic has 114wb for reference.
