CHOP SHOP
..You can have torque at zero RPM. How fast you going to go with a couple million Ft-lbs at zero RPM?:corn:
Thats how they measure torque with an electric motor. Most at 0 rpms with no thermal failure.
I may not have written it correctly but it was intended to be a separate example...
Another thing to think about that I don't think has been brought up lately, maybe in the old thread.....You can have torque at zero RPM. How fast you going to go with a couple million Ft-lbs at zero RPM?:corn:
The acceleration of your moving element is a result of your net force or torque.
Sorry I am an ME and size electric motors for automation applications all day. All of this is right up my alley.
Exactly!...You can have torque and not move AND have no power. If it turns there is RPM and there is power....If you are creating torque but not moving, then what ever is preventing you to move "has an equal but opposite force". Its just like pushing on a brick wall. Push all day with as much force as you can, if the wall isn't moving then you are not generating any power.
I don't agree. I've had this conversation with other engineers who would also disagree.......I do understand where you are comming from but "acceleration" is moving something and cannot be achived by torque alone, you have to add RPM wich adds up to HP.
Hey whatever. At that level it's just a matter of terms being used. I only bring up these type of situations to help understand what these terms actually do and how they relate to a tow rig. In the end the acceleration curve will match the power curve and not the torque curve. That was the point in the first place.![]()
I still fail to grasp your contention that "425 hp is 425 hp" I really don't get how you figure that a 350lb-ft motor with 425 hp could possibly pull like a 1000lb-ft 425hp motor if like you said in the other thread "all other things like weight and gear ratio were equal" ??? ESPECIALLY the gear ratio part.
so why is a 300hp deisel more desirable than a 300 hp gas motor in a tow rig?:stirpot:
The cat in my vulva only puts out 435hp but over 1500 ft lbs of torque and it does all of that under 2k. This argument is retarded. :flipoff:
Nobody wants to hear about your vula.:flipoff:
WTF is a vula? :flipoff:
I'm thinking theres more to it than that.Which one will last longer and get better fuel economy?:;
If high horsepower is more desirable than why don't they just run gas engines in big rigs?
Who said high horsepower is more desireable? I simply expained that net torque (or force) is what make a tow rig accelerate.
Usable power range. Diesels produce more torque at lower speeds, gearing doesn't have to be too steep in order to pull.
Gas engines produce less torque but can operate at high speeds. More gearing is required to get the same torque as a diesel. Higher RPMs means more piston strokes = more losses to friction, more heat, less efficient.
Who said high horsepower is more desireable? I simply expained that HP is what make a tow rig accelerate.
This, Binder, is part of why I think the inline 6 is a better choice for diesel engines than the V8.This question also relates to the amount of Kinetic energy available from a given fuel. The higher the fuel's energy, the more work it can generate. Since diesel generates on average 15% more energy than gasoline, it can also be expected to provide more economy for a given amount of energy expended, and because of it's high compression ratio generates a very high thermal efficiency. Ergo, a comperable horsepower diesel and gas engine, you will have better effeciency (mileage) with the diesel.
Where did Newton say torque?Fixed
Newton's Laws
1. In the absence of a net force, the center of mass of a body either is at rest or moves at a constant velocity.
2. A body experiencing a force F experiences an acceleration a related to F by F = ma, where m is the mass of the body. Alternatively, force is equal to the time derivative of momentum.
3. Whenever a first body exerts a force F on a second body, the second body exerts a force −F on the first body. F and −F are equal in magnitude and opposite in direction.
