whatthe?
Air, fuel, spark. Air is easy and it sound like you've checked spark. What's your fuel pressure? It's cheap and easy to check. Check for codes, they should at least point you in some direction.
I do not think you have a pump problem, as it sounds like you have lost spark, at least at the plugs...Check for spark at the coil, if still no spark...a quick and dirty test is using a test light on the white wire of the coil, it should be powered up with key on, crank the engine-->if the test light flashes brightly, then likely you have a bad coil. If not, then pop the distributor cap back off, and check to be sure the green and white wires coming from the pickup coil to the module are not broken somewhere. IF you have a DVOM, at this point you can test to see if it is producing the A/C voltage the module needs to see in order to make spark. With the + and - leads of the DVOM connected to the two wires coming from the pickup coil, and the DVOM set to a/c volts (if not an auto detecting meter, set it to as close to 1 volt a/c as possible)--->with the engine cranking, you should see somewhere in the neighborhood of .4 to .5V a/c; If not then the pickup coil is bad.Also, yes I checked for spark by both leaving the plug in the plug wire and putting it against the block and by putting a socket extension in the plug wire and putting it close to the block to see if I could get an arch. Nothing I could see..
Do I che k for spark at the coil in the same manner as I do at the plugs?
Yes...Do I che k for spark at the coil in the same manner as I do at the plugs?
Yes you can test with a spark plug right out of the coil. But also check if u have power going to the coil with a test light also like zukkev said
Yes...
Yup, make sure the test light lights up on both wires, the pink (red) is the power supply to coil and the white is the signal wire from the pickup coil. There should be power on both key on engine off, with a bright flash on the white wire while cranking.
Personally I like to use a phillips screwdriver with a good plastic handle, and hold the shaft approx 1/4" from a good ground...BUT away from any fuel source!
Ok well my guess is going to be the pickup coil. But u need to get a test light an make sure u have power to the coil first.
Is that the unit that sits underneath the cap and rotor?
Yes...
BEFORE you take the time to do the pickup coil, make sure the magnet on the star wheel doesn't have a bunch of cracks in it. If it's cracked, just buy a replacement distributor. It should come with a new pickup coil, and magnet/star wheel, especially if you buy new and not reman...
Also, if you do replace the pickup coil, and when you remove the roll pin, make sure you line up the dot above the roll pin with the rotor contact...the gear can be reversed which will throw off the timing a tad....
i had a used distributor put in when i did the motor swap.
