Toy Pitman Arm w/heim
dangerous toy
Walla Walla
a while back i saw a toy pitman arm that was set up to use a heim on a double shear, my tie rod hits the TRE on the pitman end of my draglink on full compression and im looking for a setup that is a little more slim to gain some clearance. ive looked at skys arm with 3/4 less drop and that would help but i think the heim would take up a little less space. if anyone else has seen the heim compatable arm let me know. thanks DT
try the flat pitman arm from sky. wither way if you choose heim or TRE with your arm now it possibly will still make contact. i have that same issue and im going with the flat arm. cheap and easy fix
