fishinfool98
- Joined
- Nov 12, 2011
- Messages
- 195
- Reaction score
- 0
Re: Re: toyota cab truck on tons
Looking good
Sent from my C771 using Tapatalk 2
Looking good
Thanksfishinfool98 said:Looking good
I saw a big thread on pirate about that the other day. Most people liked the kevco with the exception of the welds but I dont recal anyone using the new moroso pan yet.matth_85 said:Saw where you mentioned an LS1 oil pan. Do yourself a favor and get the Moroso or Kevco. Even if you get the LS1 pan for free you'll still spend $150 for the baffle system and have a cast pan that will crack at the slightest hit.
How deep is the pan? Also, does that pan use a screw on filter or remote filter?ALLJ said:Caddy CTSV pan will work too got one on my 6.0
Sounds right. The sister truck to it that they built is still floating around somewhere. I rode in it when Brandon fowler had it about 7-8 years ago. Can't remember the guys name that had it last but I know he was trying to sell it last year.roll over dave said:Was on craiglist adam and tim carter built it i belive back in the day my cuz got it put new coilovers new links and 5.3 then parted it out after a year
I think mine is a ideal groover. I think I paid about 110 for the groover with two extra heads and blades. The first tire I did with a 1/4 blade and a wood chisel to knock of the lugs. I liked how easy it was to get in all the tight spots but it took forever. The other three just got hit with a 3/4 blade and that's all I'm doing. I'd rather buy new tires than spend all day groovingDirtslngr said:TN cut looks great. What groover did you get? I've looked around and just planned on getting a 60$ cheapo one
Not much to update. I got one coilover mount mocked up on the front and ran out of oxygen so I couldn't make the tabs for the other side. I had plans on buying some parts this week but it looks like I'll be buying another Toyota when I get home instead.roll over dave said:Blake somebody owned the other last i heard he redid a few things dno if it every sold where are the updates jacob
GM part number is 12577901 Dont know exact depth measures about 6 inches but it does not hang down past my transmission pan and it does have a screw on filter85toyo said:How deep is the pan? Also, does that pan use a screw on filter or remote filter?
