Toyota front leaf spring options
So if I switch out from waggy fronts to RUF's will this fix my pitman arm cornholing my spring problem? Also, can I just switch springs or will I need to do more work if I go from waggy's to RUF's?
Just redrill the perch to relocate the axle forward...
Depending on what housing you you have, you might have one of the holes in the perch already. The 84-5 housings have the hole on one side for some reason. I drilled another one in the same spot on the other side. 1.5" I think. Crash and Whitetrash wrote up something on pirate about it.
i have a budy that put two rear packs together and runs them up front it seems to work really well for him running 40's and cut fenders
