- Joined
- Mar 5, 2012
- Messages
- 53
- Reaction score
- 13
My thoughts, is it possible to flip the cylinder and reverse your hoses so the cylinder is working in reverse order of its present position? If so and you have the same issue turning left then it is obviously in the assist cylinder but if you still have issues when turning right it is to do with your steering geometry or your gear box.
If your pump were bad I would think it would have the same issues turning left or right.
My thinking it is in your cylinder and you will need to pull it down and see if it has a bent rod or an internal issue.
