CHOP SHOP
so we have dumb input of
Usng an impact,
using a torque multiplier..
this is actually really funny considering the fact that he is STRIPPING THE NUTS.
an impact or a torque mulitplier will NOT stop that from happening.. jeeze.
brad,
i would try using some extreme pressure grease between the nut and the yoke flange.
Its possible its biting / gauling and you are actually over torqueing the nut before the sleave crushes.
If the nut is biting on one of the splines (or gauling on a point) this might cause you issues.
just a thought.
I Know. The mental power going on in this thread is just plain amazing!!:corn:
The nuts not bottoming out or hitting splines. A properly set up toyota diff only has a thread or two max showing when properly setup. If your getting the nut tight enough to bottom it in the threads, then the pinion is way too shallow.:awesomework:
And yes I have used the hiimpact grease. I get it from a friend that runs crane. Its used on their machines pins. It is kinda a clear green color and sticks to everything and streches like pizza cheese. VERY MESSY!!
