toyota rear steer
84turbotoy
2
Cordova, Al
I seen a few guys from Ga at spring fling running this. Any pointers or help with tech would be appriceated.
You gotta ask more specific questions than that...
Toyota axles are pretty easy to make into rear steer axles since the axle seals are out at the knuckle ball, 3rd members are easy to flip around, etc
I wouldn't run one in anything bigger than a super light weight buggy.
Well it will be going under my truck and im gonna put it stock and try that, aint broke stock stuff yet! But im slicing it behind the cab after santa crawls. Just a cab shouldn't be a whole lot of weight :dunno: but ill try it and see what happens. Worst that could happen is pull it out and put a rear back in and then ill be linked on fox air shocks instead of leafs.
i say do it, i got a custom double rear tube frame that i cant use i will sale you for the back half.
all you need to do is cut the frame off and weld this double tube frame to it.
Re: Re: toyota rear steer
Building double tube frame rails is a Lot of work.
Lots of notching, fitting, and welding
Price and location???? flashemifyougotem flashemifyougotem
machen4x4 said:
i would let it go for $250, alot of time cutting and welding
i think its a fair price. located in scottsboro al
call jamie 256-599-2083
Bingo. Lots of work to double frame
Out of curiosity, what tubing is the back-half made of?
Is that everything cab back or just the lower rails?
Anyone need a toyota housing thats already set up for rear steer?
Im taking it outta mine...
Sent from my SCH-I500 using Tapatalk 2
Whats the specs on the ole girl and location?
Its a toyota font axle with the balls and center section cut out and flipped it is set up.for 1 link and coilovers
Amd located in columbia ky
Anything special as far as shafts or is that housing with no pumpkin or axles?
