Trail buggy build!!
LightBnDr said:
Do the rubber mounts have a small cut in the edges to insert the hose w/o having to remove the entire hose and fittings to install them?
Yeah. There's a slice in it so you just pop it on the lines. Once you clap them to the link, you'd never know the slice was there.
[/URL]] dnt like the lower shock mounts so Goin drop them 1.5 inch try get front end lil lower and I need get lower spring rate on the coils
All I have left to do is put fluids in it and fire it up! I ran into a little problem when I mocked up front suspension I used air shocks. I didn't allow for room for the spring on the coil overs so now when driver side drops out it spring hits the orbital valve. So Goin have cut mount move it back few inches
Haha, at a first glance I thought that was an 8 track player on the dash. (insert Stevie Wonder smilie) Buggy looks great and killed it with the colors. :dblthumb:
She did great for her first trip out.only problem I had was one bolt backed of on the carrier bearing mount. Also laid her over on bents and dents within first few hrs off the trailer
