tbacon38
- Joined
- Sep 4, 2010
- Messages
- 733
I just had my TH400 rebuilt clutches, pump, etc, I have a manual reverse valve body, all the good stuff blah,blah, even a new converter, I stick it back in the buggy fill it up normal routine, started the motor checked to make sure it would move and it did fine, I had to readjust the cable to take the gears correctly, so backed it out of the shop drove it around for about 15 min just going through the gears and making sure it worked perfect and did at the time. Parked for about 5 min and went for another drive, started out easy just went through the gears and worked flawlessly, so I decided to get in the gas and made a really hard pass going through all gears hard, shifted into 3rd and didn't run hard very long when I got out of the gas its like the trans went into neutral rpms jumped up like something blew apart I got out and everything looked visually fine, got back in the buggy fired it up put it in gear and nothing, will not move in any gear, so I pushed it back in the shop and checked the fluid and its correct, pulled one of the cooler lines off and no fluid is coming out, my question is can the pump just go out like that or could it be something simple.
Let me know, when your cleared for liftoff.
