Turbo or Supercharger?
It has been explained to you more than once and still you don't understand.
There is no help for you. :corn:
I said that turbo's are better, I am just arguing the other side for the sake of arguing. Clean out your hearing aid gladys, wipe the head oil from your glasses:fawkdancesmiley: I understand reading isn't one of your strong points...
I would much rather put a turbo on mi' caro than a supercharger. There I said it. Again.
And yes, there is no help for me. :mad: :mad: :mad: :mad: :mad:
:corn:
However you get there... Boost is good :flipoff:
While I own 2 turbo cars, I've ridden in both enough to appreciate...
thats the stupidest thing I have ever seen. it would be so much cooler with a turbo BUMP in the hood on one side:looser:
i'd take a blower any day, you make boost all the time with a blower, even the fanciest most expensive turbo wont spool up at idle, and if you do size a turbo for low end, you wont make any top end power. you can buy a good used eaton m-90 for 150 bucks, and it will make ~15-17 psi on a 3.0L motor. that should get you in the 250 rwhp range if you need more than that change your gears or get a v8
I'd say it's time to revive this now that I have no reason to NOT post here as stated by previous rules enforced by internet nobody's.
turbo's are fun.... I still want to try a supercharger on the MKIII, but the MKIV turbo is also fun...:awesomework:
