uh oh....
I don't see why not. there's 10 trillion toyota's with you're same rear differential out there doing just fine. (they have crush sleeves too):D
you are confusing me....
*i know to get new pinion nut/crush sleeve/bearings
I have had a pinion go sloppy due to the crush sleeve with my Detroit. It actually seemed to compress the sleeve more causing slop which in turn ruined the gears. The pinion nut was still staked. Others have had the same thing happen, seems to be more common when using the Detroit. Do a search on PBB, the topic has been covered before.
hes saying spend 5 extra bucks and buy a solid pinion spacer and ditch the crush sleeve.....because they bring the suck
megatoy66 said:
Do you need a ring and pinion? I have new 4.88 and 5.29 sets if you need. Odie.
OK, Odie's 4:88's are gone.... anyone else got a R&P
ok, now i see :hi:
Eric said:
THats not good looking, How and where did that happen?
i was drag racing after drinking a case of beer... should have stopped at 1/2 of a case
...honesty have no idea. i think it was something that was about to go at any minute and decided to wait till we go back from reiter
Call the hook-up and go with Yukons. Dump the the Detroit and get an ARB. Call me when/if you need a hand. That is all, carry on.:D
I have done hundreds of toy diffs w/wout crush sleeve and no problems either way.
Darius---buy some real tools :rolleyes:
0 Words
