What kind of problems have they had? I thought it was essentially the same engine as the 5.9 with a larger bore.kcmwgreg said:they have had a metric **** ton of problems with the 6.7 . we have had at least 6 in the last month all needing motors
kcmwgreg said:we got some new info at the dealership where i work . there are plans for a 2010 mega cab long bed but the body might change . also they dont know how long they will have a cummins power plant . dodge has there own diesel in the works for the 1500,2500 3500. 4500 , 5500. will have ops. like cat , bens,cummins , they have had a metric **** ton of problems with the 6.7 . we have had at least 6 in the last month all needing motors
POPS58 said:I know where you can get a 2003 F-250 four door all leather,Edge,22" wheels,some kind of big tires,little over 100,000 miles,goose neck ball,trailor brakes,4.88 gears,All engine work needed to be done by Ford done,This truck will pull anything,ready for a new home.PM for more info.
B Gillespie said:Oneal needs to get on the horn with Chrysler and get them to start making a 5500 Mega Cab with at least 84" C-A.
jabnasty said:ill sell you my d max welding rig cheap. Just hit 100k today.
apeters89 said:What kind of problems have they had? I thought it was essentially the same engine as the 5.9 with a larger bore.
J.A.B said:The 6.7 is tolerable as long as you never let the motor idle / drive in town . or hell stop period while it is running![]()
