Elliott said:I know he put a mud truck case in blue, but aren't they offset on the outputs like the big case,I guess what im asking is It looks like the same rear axle how did he run the driveshaft?
Neal3000 said:I can see prep time making a big difference in helping you finish the race but not in actual performance during the race if nothing breaks.
What kind of money do the top bouncer rigs have in them? Seems like you can get a top notch straight axle ultra4 car (like Will Carters) for around 100k
Personally i Believe the big difference is the amount of time put into shock tuning and researched and engineered suspension setups.
We already know that a ultra4 car can do all the top climbs, Peter Basler proved that.
They need to make the climbs harder in these shootouts, put some big stuff in that will be hard to do with 39" tires
redbarron said:I am certainly not an expert on either, but I would say the difference in tires is helping as well. Eric Miller came over and talked with us, he said he was running 20psi of air in his tires. I don't know what the rock bouncers run in theirs(I assume less than 20psi )but the SX seem to be compounding the bouncing. I am not trying to start an interco vs every other tire debate. Just my observation. I could be dead wrong as a am just an old school crawler. I ran 15psi in my red label and they seemed to have much less deflection than the LTB's I had to run at 5 psi. He also said they tear the car down after every race and had 40 hrs in tuning the shocks alone.
Cole said:383 stroker, th400, straight drive, 14 bolts, front axle has Ouverson Knuckles and C's with 40 spline RCV inners and 47 stubs I believe and rear is a stock 14 bolt with rcv axle shafts.
bigdude said:How much if any 0.25 wall is in the chassis? As many times as I have seen it beat on and rolled I don't remember a single tube, mounting point, or chassis failure
Cole said:Mike Bergman in his buggy called The Statement. Got a little close on this one www.youtube.com/watch?v=tQlPlpEvOBI
bbone said:6k lbs?....I thought mine was heavy @5k
Cole said:Danny was the fastest bouncer www.youtube.com/watch?v=O6xktCKKljQ
zebrajeep said:I agree with the tuning comments, however, watch Danny in this video. What does he do differently?
Is it tuning?.......probably not
Is it the line?.......same line as others
Is it the tires?......same as others
Is it more horsepower? Probably not
I think it is smoothness. But what is smoothness exactly? It's somehow keeping the tires on the ground and hooked up.
The guys who win are able to let off and re-apply throttle at EXACTLY the right moments to keep the bounce to a minimum and stay hooked up.
Very impressive.
