RebelRider
We used to run water in our Atv tires. The only way to get it all out is to dismount.
ecoast said:what's easiest way to get the water out?
valve stem @ 6 o'clock and a small tube down inflator with valve removed?
break down tires/beadlocks?
drill and plug hole?lol
any ideas?
RebelRider said:We used to run water in our Atv tires. The only way to get it all out is to dismount.
any ideas?
Most places that put water in tired have a pump system the well put the water or ballast fluid and also pump it back out. But to get %100 out , you'll have to break down tire. Just thinking, you might be able to just knock the bead off of one side, then use a shop vac to get it out.
Deep water riding. It's better to stay planted on bottom than having it float out fromsmbroady82 said:What is the advantage to running water in atv tires? Just curious
