What do you do for a living?.
I work for a precast concrete manufacturer, We make underground utility products, for storm drain and sanitary sewer. We are located in Murfreesboro, TN.
I'm an electronics tech. I do industrial controls with PLC's, drives, motors and stuff at a company that makes wire.
I was a lubrication engineer for a few years.
Now I design and build machines, production equipment, automation, test stands, whatever the customer asks for.
Is that a step up or down from fluffer? Sorry, I am not "in the know".
I had a fab shop for about 12 years and just got burnt out. Now I work for a gasoline refinery.
Maybe you can come figure out what's wrong with our effing automatic quick-roll-up warehouse door. Heard PLC was bad or something and the door is dated and parts are scarce for it. But our maintenance has it under control.....haha. You work for Southwire?
Probably Made by Siemens. :flipoff1:
This should get your OCD going. It was pretty when I started, but didn't work. laughing1
Built natural gas pipelines for 10 years, wife got tired of never seeing me. Got a job at home for BNSF railroad and hated it, now I work at Nucor Steel.
Re: Re: Re:
TacomaJD said:
I thought you worked on the cleanup crew for a large pornographic film company.....
I believe his official title is "cum dumpster"
Worked on Toyota's for 17 years, new owners, so i left. Working on forklifts and other equipment. Getting ready to take some marketing classes, a salesman is retiring in a few years and i want the job.
Sent from my SM-G935V using Tapatalk
Low voltage tech. Fire alarms, intrusion, cctv, access control, nurse call, intercoms, AV, voice and data. Pretty much if it has wire, or wireless, and isn't full on electrical like power or lighting I do it. Currently moving from senior service tech to service manager, just have to train a replacement. Been at it for almost 20 years. Started as a cable guy, went to work for waldevil doing their fire and burglar alarms and after 12 years they decided contractors were cheaper so became a contractor for a bit then found a local company and here I am 6.5 years later.
Working as an Industrial Engineer for Volvo trucks.
Line efficiency & lean manufacturing (green belt) are my main focus areas.
Re: Re: What do you do for a living?.
Which Nucor plant do you work at, Decatur AL? My bro in law works at that one.
So I can pm you and bitch when my Volvo breaks down? Matter of fact I have had a check engine light on for the last 2200 miles. But the truck is still pulling.
Sent from my Pixel using Tapatalk
