With those specs I think a 3300-3600 would be about right you might have a little more flash stall than you are used to but I think you will love how the power comes in, also ls motors like high rpms and that cam will need 3300 at least to not load up (side note people talk about stall rpm a lot but most don't understand what it actually means. For example just because you have a 3300 stall doesn't mean it won't move until you reach 3300 rpm it means that the converter is applying all fluid pressure at 3300 so in your rig that would mean in high gear high range your converter would slip a lot until you get the rpms up but in low gear low range there isn't as much force required to turn the tires so it will start to pull around 1000-1200 and will be locked up around 2000) hope that makes sense stall rpm is a special type of vodoo Magic that takes a lot of understanding of how it works to get the best setup. Every different aspect of the rig effects the stall rpm weight, gears, motor output, motor power curve, transmission and rotating mass/ parasitic loss
