Technician
- Joined
- Jan 11, 2013
- Messages
- 931
- Reaction score
- 0
Yes
I do this with the 5 speed.TBItoy said:You'd need a 4:1 kit in the 300 if you really want to crawl (or run a 231/300 doubler).
The only part I liked about the auto was the ability to up or down shift at WOT
Well me too, but the auto did it faster, or at least with out losing momentum (as much momentum you can generate with a 22re...)smurfy90 said:I do this with the 5 speed.
Technician said:2JZ-GTE to AW4 to DANA300. May need a sissy bar for the passenger.
Do you have an A340 lying around that ypu want to use? The AW4 will bolt up to the 2jz and will bolt up to the dana300 with a $50 clocking from Novak. No need to add a tail shaft????84mallcrawl said:this is a swap that I am looking to doing except with a 2JZ-GE to A750(maybe), A340 with AW4 tail shaft to dana 300
