billstoy
- Joined
- Sep 29, 2011
- Messages
- 1,411
- Reaction score
- 36
There is a rule of thumb larger tires the longer you can go a good area to start 90" with 35's to 120" with 44's . that is a ball park. some things can vary like ride height and belly height.. wheel base works to clear belly snags. flat belly may run longer. Both of mine are 110" one on 42" and one with extra belly clearance with 38" with the 38"s. I may go to 108" If you had access to scales you may move front and rear in up or back to get weight ratios where you want. Some may argue ,,
Just my 2 cents.
Just my 2 cents.
