Wheeling with Celebrities
Doesnt count stacked rocks on backdoor..... Man the people on fb were all over you about that.
I don't care how many rocks are on backdoor it is still a hard climb, and for the record I didn't put all those rocks there.
Here is part2 where we went to Big Bear!
Ian looks very high geared. Is he just running a 205 in his buggy?
The gearing is good. It has an atlas. He requested a low stall in the converter, But after the install come to find out the trans builder sent it with a 2500 stall. Im sure it will get changed at some point.
@Blackbeard. I'm using google to view the site on a iPhone. These videos will not play, I can scrub through it and the video changes but will not play. Tried stopping and starting but nothing. It's pretty much every video on the site.
I'm not sure what a google view is, but I just tested it on my iPhone and it works with out pause.
Damn I would have thought it was higher than 2500. I hope I don't hate mine. Its either 2500 or 2800.
Running regular JD Hy-hard is supposed to tighten it up about 200 rpm over low vis or ATF depending on the converter. If you still plan to run it that is what I would try. 2C
