1977 Ford Bronco, 302cid, C4, with an aftermarket TBI injection setup on an Edelbrock intake. The problem is that just about any time the brakes are applied while in gear, such as holding speed down decending a rocky trail, the engine will rev uncontrollably. It will also rev uncontrollably just about anytime you put it into Drive, 2nd, or 1st (does not seem to do it when going into Reverse...) from Park while the brakes are applied. It will not idle down until it's back in Park and then takes several seconds to calm itself down. You can imagine the fun this causes on the trail, or even in a parking lot...
The only thing I can think of is a vacuum issue causing the MAP to go all whacky, and this was somewhat verified with a vacuum gauge - it reads a steady 14" at idle but slowly tapers off when the brakes are applied while in gear, and the RPM's raise as the vacuum decreases (it holds steady at ~13" with the brakes applied in Park).
So the big question is, WHERE is my vacuum going while I'm in gear with the brakes applied? Does this sound like some sort of issue with the modulator on the C4? Any help would be appreciated!!
