What are the actual mechanical differences between the couple of different lockers that the detroit name sells. I know that there are a couple of different ones...just don't remember the names for all of them off the top of my head.
wentz912 said:What are the actual mechanical differences between the couple of different lockers that the detroit name sells. I know that there are a couple of different ones...just don't remember the names for all of them off the top of my head.
U sure? Toyota didnt offer factory e-lockers pre 95 in 4runners, only land cruisers.FordFrk06 said:i got a detroit in the rear, and an e-locker out of a 94 runner in the front. my only issue with the e-locker is that it doesnt always fully disengage. other than that i love it.
KarlVP said:For daily driving street use they aren't BAD. You just have to get used to them. I daily drive my rig and it has a few quirks, but nothing I can't handle.
all i know is what odie told me, its out of a 94 4runner limited.Alpine4x4 said:U sure? Toyota didnt offer factory e-lockers pre 95 in 4runners, only land cruisers.
KarlVP said:The Detroit Truetrac is a full carrier replacement but it is a limited slip device. Great for tow rigs or mild wheeling, but not worth it for more serious wheeling.
The Suretrac is like an open differential but backwards. When one wheel starts slipping, it applies the torque to the wheel with the MOST traction.
well its more of it does unlock but when he goes around corners its usualy locked back up because of accel64FJ40 said:Then he didn't check the thrust clearances. In some instances, due to variances in carrier manufacturing, it's necessary to swap thrust washers (cheap at the dealership) to obtain the correct gap. If it's too tight, it'll never unlock.
wentz912 said:Soo....the Truetrac and the Suretrac are essentially the same thing then? Because now that I've thought about it. I won't be doing anything more than mild wheeling with my stock axles and some 30's, maybe 32's sometime later on this year. If I ever being able to afford to get into wheeling a little more hardcore. And if I am able to get into it more, I will definitely go into some fullsize axles...yada yada yada you know. Which would defeat the purpose of spending a bunch of money on traction aids for my stock axles correct?
Musta been swapped in from a newer rig then.FordFrk06 said:all i know is what odie told me, its out of a 94 4runner limited.
Jaydog said:For mild wheeling, if you have good suspension, you don't need a locker. I can run every trail at Evans open, and it's pretty mild.
See that's my problem. I'm probably going to stick with stock or at least something close to it until I go to fullsize axles. So basically I NEED a traction aid ya know? And like I've said before, I haven't run into a lot of problems where I've needed a lot more flex instead of needing power to the other wheel.Jaydog said:For mild wheeling, if you have good suspension, you don't need a locker. I can run every trail at Evans open, and it's pretty mild.
Explain. Mainly the only problems i see are chirping on corners and a lil more tire wear...not much worse than any other auto locker. They still chirp around corners if the rear axle is getting power and wear out tires just the same...only downfall to a spool is not being able to coast aorund corners and not chirp. Spools also have less parts to break since they are one part:redneck:SeaRubi said:if you're not going to upgrade your axle shafts, truetracks front and rear aren't a bad way to go and will get you quite a ways further down the trail than being open. they're easier on the drivetrain than a detroit.
welded rear or spools is not good for a street driven vehicle![]()
Alpine4x4 said:Explain.
