zukkev
Cornfuzzled yet again...
I haven't done the math, but I bet with everything taken into acct, I wouldn't be surprised if my COG dropped by nearly 3" with the changes I made...
So long as you sidehill with the downhill side to your pass side, your GTG!!!:;:fawkdancesmiley:You'll have to compensate for weight gained too (not talking about your rig):fawkdancesmiley:
Damn It! I posed that, then realized that my COG is probably REALLY bad if my rigs leaning to the driver side:haha:
If the CG is fixed, it's fixed. If the suspension is moving around so is the CG...........
Not only did I not fix the trans but now the steering is jacked too.
that's OK I can outwheel you with the superduty.
I did say there are many variables but I was using the physical properties of the rigs size itself as that seems to be the typical argument going...."a wider rig is more stable and safer"![]()
:haha::haha::haha:
Wait, what happened to your steering???:yikes:
a wider rig, is usually also heavier and higher....speaking full-bodied rigs, no the buggies.
Weight doesn't matter and the overall height doesn't matter but the height of the CG does when leaning.
What is this Anti-wrap bar you speak of Jeff? and what is its purpose? LMAO....I though it was all related to how big your steelies were?On a leaf sprung rig...yes,wider is better depending on how their Anti-wrap bar is built.
Well, it tis past 7...:haha:
Why does a rig roll?
Usually, because the driver is drunk, high, slightly mentally handicap'd, with 1 bad eye and the other has 20/60 vision, driving a 10 ft tall 70" wide, 85" wheelbase Jeep-like (seems to be the politically correct term) on 31" AT tires. Also, the cage is made out of old handicap shitter rail tubing with welds from a 1942 arc welder, and has a b pilar hoop. The seat belts are pieces of rope. But, its got a SBC 350 pushing 600 hp!:cheer:
Yes so maybe we should argue height and weight restrictions?:corn:
