exactly why i said what i said. it all works as a whole unit and i have experianced quite a few failures where the pinon walked into the ring gear and caused damage. the pinon was loose. whether it streched or the housing flexed i cant say.
ive also seen a new install kit come from randys with pinon bearings way oversized and just slid on the shaft with no press. causing a loose sloppy bearing. when this was discovered and replaced the new stuff was the same out of tolerance.
the only other failures i seen repeated a lot are failure of ring gear bolts...
all in all i believe the consensus of this is size. 8 " too small for the forces being generated.
