Neal3000
Shoulda followed my troubleshooting tips, you could have saved a lot of wasted time :****:
Neal3000 said:Shoulda followed my troubleshooting tips, you could have saved a lot of wasted time :****:
Neal3000 said:Get a lighter and turn it up high
Crank up the pane full blast
Start unhookng **** and stick said lighter up to it
Find your problem or die trying fawker
al1tonyota said:You prob just didn't have the clutch pushed in all the way, the clutch system has air in it or the rod between to space cylinder and clutch fork has gotten out of adjustment. Or also possibly the rod on he pedal has gotten out of adjustment.
TacomaJD said:like I'm about to get to learn all about Toy 5 speed trannys...uke:
onetoncrawler said:as easy as they are to come by, I'd just swap it out with another and then tear into yours to find the problem - if it can be fixed then you can sell it or have a spare
But he drives a SamiBlase said:WISE MAN RIGHT DER! Someone should change his name to Yota.
TBItoy said:I may not remember correct, but I thought that the "red baron" had an r151 (turbo trans) in it.?
If it's an R151 you need to hold on to it. Not easy to find.TacomaJD said:I have no idea what it is, you need pics of anything specific on it to tell?
