Wicked YJ
  • Thread starter Thread starter Cole
  • Start date Start date
I still run a steering box on the ol Willys, but I moved the tie rod behind the axle (drag link is still in front). Could you not use high steer arms flipped around to put the ram on the rear side of the axle? Anybody ever tried it? :dunno:
i have a set of high steer arms but at full bump they would be in the frame
Looks Good :eek: thumb.gif
You get the brakes working, was speaking with a tech @ your
problem and he said never to actuate pedal when dry b/c it
gauls a seal and will never be right wthout a rebuild. Hope
its already fixed.
Matlock
i took the rig out yesterday and it did great other than the front lock rite taking a **** first thing and i have a two axle seals leaking oil, i still need to put a bigger master cylinder on the front to fix my brake problem.
none yet no one i ride with carries a camera lol but i have wheeled it about 5 times and it is doing great other than me cutting 2 tires. i also have swapped in the 1" bore master cylinders and that realy helped the brake problem
