Wide Open Design build of an Evolution chassis ( WFO )
From on of the flexed pictures you would be correct. The suspension will let on shock bottom out if it was impacted totally on one side while the other side is completely dropped out. But, I set it up to where you get the most amount of up travel possible when the axle is fully compressed. Fully compressed meaning both sides compressed all the way up at the same time. When that happens the air bumps bottom out just be fore the shocks do.
Re: Wide Open Design build of an Evolution chassis ( WFO )
Got her broke in now!
Got a little seat time this past weekend before the race.
A buddy hooked me up on wrapping the beater skins. It turned out great and it cleaned up easy
Damn nice buggy guys. I had a chance to rub up on it at the SRRS race and it is top notch.. I knew it would not take long to get the pretty beat off of it with BJ behind the wheel.
Photo gallery is up. I need to send a huge thank you to Ricky B!
http://www.rickybphotography.com/Rig-Features/Wide-Open-Design-WFO/28885843_Z4rzXg
And for the specs...
Chassis
WOD Evolution
Modified roof and rear
1.75" DOM with a mix of .250, .188 and .120
3/8" aluminum skid and boat sides
Suspension
King 2.0 remote reservoir coilovers
14" front
16" rear
King 2.0 bumps
WOD 7075 2.5" lower links
WOD 7075 2.0" upper links
QA1 chromoly 1.25" heims
Currie Antirock rear swaybar
Twisted Stitch limit straps
Engine
Turnkey Engine supply LS3
Kenne Bell supercharger
710hp 700ft lbs
Air to water intercooler
A1000 fuel pump
8 rib front drive system
Sanderson headers
3" into 3.5" nitro plate exhaust
Magnaflow muffler
Transmission
PTC TH400
PTC 10" converter
Transfer Case
Atlas 3.0
400M output
Race gears
Short HD output
Axles
Torq 14 housings
Torq 14 drop outs with load bolts
WOD trussing
ECGS spools
4.56 gears
RCV 40 spline Rockwell CVs
WOD knuckles
WOD 4 piston brake kit
WOD brake rotors
Yukon hubs machined for 40 spline
Chromoly spindles
Solid drive flanges
4130 drivelines with 1410 joints
Wheels/Tires
43" TSL SX stickies
TrailReady HD 17" wheels
Steering
PSC 8" double ended rams
QA1 7/8" heims
WOD 7075 tie rods
PSC 1700 series superflow pump for front steer
PSC CBR pump for rear steer and hydroboost
PSC race orbital
WOD column
Stazworks return to center rear steer controller
Interior
WOD custom dash
Autometer gauges
Winters shifter
Twisted Stitch seats
PRP harnesses
Lokar throttle pedal
Wilwood brake pedal
Grant steering wheel
Misc
WOD custom fuel cell
WOD intercooler water tank
LazerStar lighting
Warm 9.0 RC winch
3 stage white paint
Sparkle silver powder coat
Griffin Radiator
Howe trophy truck steering cooler
Plate style trans cooler
WOD cooler rack
Stainless catch cans with rollover valves
WOD hydroboost
Werken gel cell battery
Fragola AN plumbing
In the second photo, what airport was he landing at........................................... That was definitely a " hold my beer, watch this" run loller.gif loller.gif
Yes they are the aluminum version. I'm not even sure the nodular setup was available when I got them.
It's been great with the exception of the motor running right and that is being addressed right now. The buggy rides great, claims great, comfortable to be in for hours at a time and visibility is excellent. As soon as the new electronics are on the motor and its tuned it should be even more fun.
Fired her back up today with MAST Motorsports engine controls and wiring. Tomorrow is dyno tune day!
Where's the dyno numbers?
It's still on the dyno. Delk Performance squeezed it in to a packed schedule and agreed to dove into the Mast tuning software for their 1st time. Should be done today but we are expecting numbers north of 230hp.
:eek: 230! U sure you can handle all that BJ, seems like kinda high expectations! laughing1
molaugh molaugh molaugh
expecting 70-80% drivetrain/tire parasitic loss :spin:
