So in order to make this happen the "right way" i need a bit of a redesign as I was planning on mounting with no slip, no bushing...but drivetrain mounted on poly bushings (at the motor mounts, the back of the trans, and the back of the Atlas).
I don't have a lot of room to add in big bushings, etc. I can however possibly add some flat poly between the 2 sides of your carrier bearing mounting plates. What are your thoughts on (with no slip in the midshaft) cutting down some poly bushings and putting them on the bolts between the two plates that bolt together? Would that suffice as a "bushing", or would that cause too much movement and vibration in the shaft.
