pholmann
This is true also.
al1tonyota said:It sucks more when you go for the best/nicest things and it still doesn't hold up.
All up to the owner but the piston hit atleast once metal contact, maybe it didn't hurt the bearing at all but changing out a $5 part is cheap to ease my mind.
redneckengineered said:Oh, I was hotter than satan's taint. Like I said, I'm not a motor guy so I pay top dollar so I don't have to worry about **** like this. I actually feel a little bit better after finding what I think was a defect in the rocker. I can at least accept the **** happens scenario. We'll see what Mast says about it. Thanks for the advice on the bearing, I'll mention it to Mast and see what they say. I pretty much go with their advice, since they built the engine.
TBItoy said:Defective rocker = replace all the rockers
At least IMO.
Probably with some billet ones instead of cast.
mna0121 said:Haven't seen it mentioned but I will throw this in. Before you begin de-burring the piston wipe some clean grease between it, the piston, and its bore, don't pack it in just build a barrier around the bore. Keep the piston at TDC where you have it in the pic. also put something, tape and plastic, over the rest of the engine to keep the junk out of the rest of it. Once done de-burring use your shop vac. to suck up the grease and piston dust, start the piston down its bore about 1/4 inch or lees and wipe with a lint free rag damp with brake part cleaner, move it down a little more and repeat with another damp rag. Over Kill!!!! you can never be too clean when assembling an engine. Once done spray WD-40 on the bare surfaces of the block including the bores but don't soak the bores, wipe them with those lent free rags. Bag it up till you are ready to put it back together. RTR
