WVO duramax Build
So does the WVO system work well?, are you happy with the results? did any problems/$$$ arise down the road??
its working fairly well, but I'm still scared to run 100% wvo. it seems to work better at higher RPMS (aka not at idle), but I think it might be the FASS pump pressing on the lift pump.
I usually mix the WVO with 20% diesel in the 49 gallon tank to thin it out a bit, although in the summer I bring that down a little more.
But on the road it does great, I see no issue towing and it smells AWESOME :awesomework:
nope, but I use VoControl to switch it to diesel before it gets shut down. The OE tank is still 100% diesel.
