TBItoy
Re: Re: Re: Your Great Idea?
Ah, I gotcha. I think that would be pretty easy to make with a "driveline brake" type setup, just get a gear plate cut to sandwich in the driveshaft (or on the pinion of a Rockwell) and use an air cylinder to engage the spur catch mechanism, you could put a return spring on it to pull the catch out of engagement when the air pressure is not applied.
Eddyj said:Because the gear/stopper would only keep you from rolling backward it would have no effect on forward movement plus it would be just holding a button not having to reach or worry about timing a release
killer craftsmanship bro
